ACE- SSL Termination with ssl url rewrite (URGENT)
Mar 8th, 2008
i just upgraded to ACE 2.0
ssl termination with url rewrite not working
when i put https://172.16.211.50 i am redirected to http://172.16.211.50:9080/cseipoms
i want the ACE to terminate the SSL and the user get the following: (SECURE)
https://172.16.211.50/cseipoms
i don't want the user to redirected to nonesecure page
know i get the SSL Certificate popup after that i am redirected to nonsecure page
Gilles Dufour Sun, 03/09/2008 - 01:26
  • Cisco Employee,
what is your config ?
And is your server using a redirect to send you to http or is it a hard link ?
the rewrite function only works with the redirect.
Gilles.
majaj Mon, 03/10/2008 - 03:53
thanks
know its working fine , but still i have problem , when i put user name and password in the web page, it show session timeout
the application developer said that because the traffic is going to different server each time
Persistence-rebalance does not solve the problem , do i need to configure sticky group?
Gilles Dufour Mon, 03/10/2008 - 06:07
  • Cisco Employee,
yes, you will need some form of stickyness.
Gilles.
harrjd222 Mon, 03/10/2008 - 06:48
Is there a sample config of how to config url re-write? I thought wasn't available until the 3.0 ace code comes out.
Jeff
harrjd222 Thu, 03/20/2008 - 10:59
Gilles,
Can you check the url again this seems to be an online dating site.
Jeff
a12288 Mon, 07/28/2008 - 11:43
I have the exact problem, did you figure it out?
