Terminate multiple PPPoE on single IOS Router
robertblasey
Hello Everybody,
I am looking for a high-quality option to terminate 3 or 4 sDSL/aDSL PPPoE sessions on a single IOS device. Can I use the HWIC-4ESW in a 2801 for this idea? My experience with VLAN interfaces in routers are somewhat limited ...
Thanks for reading
robert
Another question: Is the WIC-1ENET module running in the current 1800 or 2800 models?
paolo bevilacqua
Hi Robert,
The HWIC-ESW is know to NOT work with mutiple PPPoE connections to different port. For that, you will need to add 1 or 2 ports FE cards dedicated to each connection.
The WIC-1ENET is not supported on anything but the 1700.
didyap
Level 6
Level 6
You can use the forwarding feature for this. For example, users coming in with username@lnsdomain.com would be forwarded across the tunnel with the following configuration:
vpdn enable
vpdn-group l2tp
request-dialin
protocol l2tp
domain company.com <- forward all users that includes "@company.com" across this tunnel.
initiate-to ip x.x.x.x
l2tp tunnel password 7 061118
vpdn-group pppoe
accept-dialin
protocol pppoe
virtual-template 1 <--incoming pppoe clients will clone from vtemp1.
interface Virtual-Template1
mtu 1492
ip unnumbered FastEthernet5/0.1
peer default ip address pool pppoe
ppp authentication pap chap <--I MUST specify incoming authentication
method to identify users for transport over L2tp tunnel.
paolo bevilacqua
Hi Robert,
Thanks - its sometimes really hard to find the real facts between all the sales mumble on a website :-) - if you dont have a 4ESW laying arround - the feature-navigator is not always helping ..
Tanks a bunch -
Robert
Thank you for the appreciation and good luck!
