Import Certificate to ASA
Mar 8th, 2008
Is there a way to import a certificate to an ASA? Say for example I used to do remote access with another solution and had a certificate for that product. I can export the cert with the private key from there and want to put it on my ASA. Is there a way to do this? It's darn simple on Windows, but I don't see any similar way to deal with this on an ASA. I would like to avoid having to buy another certificate when I have one that works well and has several months left on it.
Thanks for any help!
