2960G uplink
Mar 8th, 2008
hi guys,
i've got four 2960G-48TC-L switches. i have to uplink all four to a catalyst 4500 with a single GLC-SX-MM, and i figured i would connect the switches to each other with GLC-T modules, and uplink the one that is on top of the stack. so the question is: is it lame to connect three of the switches to only one, or should they be connected to each other as well?
lenpet_hun Sat, 03/08/2008 - 08:26
well i just realized, that the four uplink port on the 2960G-48TC-L are dual purpose ports, so i'll just use rj45, i don't need the GLC-T at all (but correct me if i'm wrong)
glynnd Wed, 03/12/2008 - 22:46
yes, you can just use the copper ports rather than the fiber ports if distance between the 2960 and the 4500 is not a problem
