WIC card
Answered Question
Mar 8th, 2008
I am looking to do frame relay in a lab. I am looking at getting 4 WIC-1T cards and then 1 other card wither a NM4-T or a NM4-A/S card. This card is going in a 3620 or 3640 for a frame relay switch. Which card should i go with? I have found the NM4-A/S cheaper would that card work?
Correct Answer by paolo bevilacqua about 9 years 1 month ago
Yes it will up to 128 kbps in sync mode. Don't forget the dce cables.
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Sat, 03/08/2008 - 09:29
  • Hall of Fame,
    Founding Member
