Reliable Static Routing Backup Using Object Tracking with DSL & DHCP
Answered Question
Hi, I have two ISP's connected to a Cisco 1760 IOS ver 12.4-8 and one is providing PPPOE over a WIC 1adsl and the other cable modem through a WIC-4ESW by DHCP. The problem is I modified a Cisco example which works and I can get the PPPOE as the default route BUT I want the DHCP route (which is 8Mbps versus 2mbps for the adsl)as the default, try as I may I just cannot achieve same. Please see my running-config below (edited for salient lines only)
ip sla monitor 1
type echo protocol ipIcmpEcho 72.27.0.1 source-interface Dialer1
timeout 1000
threshold 40
frequency 3
ip sla monitor schedule 1 life forever start-time now
ip sla monitor 2
type echo protocol ipIcmpEcho 72.252.205.1 source-interface Vlan1
timeout 1000
threshold 40
frequency 3
ip sla monitor schedule 2 life forever start-time now
ip tcp synwait-time 10
track timer interface 5
track 123 rtr 1 reachability
delay down 15 up 10
track 345 rtr 2 reachability
delay down 15 up 10
bba-group pppoe global
interface Null0
no ip unreachables
interface FastEthernet0/0
description $FW_INSIDE$
ip address 10.0.0.138 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip nat inside
ip virtual-reassembly
ip route-cache flow
ip tcp adjust-mss 1452
speed auto
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface ATM1/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
bundle-enable
dsl operating-mode auto
hold-queue 224 in
interface ATM1/0.1 point-to-point
no ip redirects
no ip unreachables
no ip proxy-arp
no snmp trap link-status
pvc 8/35
pppoe-client dial-pool-number 1
interface Vlan1
description $FW_OUTSIDE$
ip dhcp client route track 345
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip route-cache flow
interface Dialer1
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip flow ingress
ip nat outside
encapsulation ppp
ip route-cache flow
dialer pool 1
ppp authentication pap callin
ppp pap sent-username user1 password 7 2
ip route 0.0.0.0 0.0.0.0 Dialer1 track 123
ip nat inside source route-map fixed-nat interface Dialer1 overload
ip nat inside source static tcp 10.0.0.13 8080 interface Dialer1 8080
ip nat inside source route-map dhcp-nat interface Vlan1 overload
access-list 110 permit ip 10.0.0.0 0.0.0.255 any
no cdp run
route-map fixed-nat permit 10
match ip address 110
match interface Dialer1
route-map dhcp-nat permit 10
match interface Vlan1
END OF EDITED CONFIG
Show ip route:
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 10.0.0.0/24 is directly connected, FastEthernet0/0
S 10.159.10.3/32 [254/0] via 72.252.205.1, Vlan1
72.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
C 72.27.0.1/32 is directly connected, Dialer1
C 72.252.205.0/24 is directly connected, Vlan1
C 72.27.176.50/32 is directly connected, Dialer1
S* 0.0.0.0/0 is directly connected, Dialer1
NOTE: The DHCP route's admin. distance is defaulted to 254
Show Ip route track-table:
ip route 0.0.0.0 0.0.0.0 Dialer1 track 123 state is [up]
ip route 0.0.0.0 0.0.0.0 72.252.205.1 254 track 345 state is [up]
NOTE: Again the admin. distance of 254
Any Ideas on how I can set the default route to Vlan1 (DHCP) ?
I tried changing the vlan1 to track 123 and setting the static route to 72.252.205.1 but that doesn't work. Can you guys help.
Correct Answer by Richard Burts about 8 years 11 months ago
Gerald
I believe that what is important in what appears in the routing table - and that is a single route. I believe that the output of show ip route track-table is incorporating information from some working table and in that working table it should not be an issue if there are several appearances.
I also not that the alternate default route learned through VLAN 1 has admin distance of 254. So I would suggest making the floating static through the dialer have a weight lower than 254 (perhaps 250) so that it would clearly be the next route to insert into the routing table.
For rating posts there should be a small drop down box in the lower right corner of posts (other than your own) which you can access when you are logged in to the forum. There is also a small check box that can be used to indicate that your issue has been resolved.
Rick
Overall Rating: 5 (1 ratings)
Richard Burts Sun, 03/09/2008 - 06:07
Gerald
There are a couple of things in your post that puzzle me. The IP routing table has this static route:
but I do not see this route in the config. I am also puzzled that the show ip route track-table sees 2 default routes where there is only 1 that shows up in your posted config. Do you have any insights about these?
I do have a suggestion to make:
- reconfigure the static default route through the dialer to make it a floating static default:
ip route 0.0.0.0 0.0.0.0 210 Dialer1 track 123
- try this for the primary default route:
ip route 0.0.0.0 0.0.0.0 dhcp
I do not have direct experience with this, but the documentation looks like it may do what you want.
Give it a try and let us know whether it works.
Rick
Rick,
That route was inserted by the DHCP mechanism and I am also puzzled by same. But I tried your suggestions and none seem to work. The ip route 0.0.0.0 0.0.0.0 dhcp doesn't allow the dhcp keyword and I used the ip route 0.0.0.0 0.0.0.0 Dialer1 210 track 123 (I noted you had the administrative distance 210 after the netmask but that gives an error, so I corrected as shown here and it didn't work either. Even when I use 'ip route 0.0.0.0 0.0.0.0 Vlan1 1 track 123 ' that didn't work as tried previously. Any other suggestions ?
Gerald
Richard Burts Sun, 03/09/2008 - 16:24
Gerald
The wrong order of the admin distance was a mistake on my part. Thanks for finding and fixing it.
I did some more checking on the ip route dhcp option and found this in the command reference:
The following example shows that using the dhcp keyword in a configuration of Ethernet interfaces 1 and 2 enables the interfaces to obtain the next-hop router IP addresses dynamically from a DHCP server:
ip route 10.165.200.225 255.255.255.255 ether1 dhcp
ip route 10.165.200.226 255.255.255.255 ether2 dhcp 20
So I wonder what happens if you try to configure:
ip route 0.0.0.0 0.0.0.0 vlan1 dhcp
If we can get the DHCP default route into the routing table without the distance 254 then it makes sense to try to assign an admin distance to the dialer default route. Until we get the DHCP route without distance 254 there is no point to trying to do anything different with the dialer route.
Rick
Thanks again Rick,
Ok, after entering this 'ip route 0.0.0.0 0.0.0.0 vlan1 dhcp 1' command. It wouldn't allow a track keyword.
I now have this (interesting or changed portions only shown):
Sh run:
interface Vlan1
ip dhcp client route track 123
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip route-cache flow
ip route 0.0.0.0 0.0.0.0 Dialer1 254
ip route 0.0.0.0 0.0.0.0 Vlan1 dhcp
(Note there is no track command attached to any route)
It seems to work but I get a double entry of the vlan1, as shown below:
Router#sh ip route track-table
ip route 0.0.0.0 0.0.0.0 72.252.205.1 254 track 123 state is [up]
ip route 0.0.0.0 0.0.0.0 Vlan1 72.252.205.1 track 123 state is [up]
See Track info:
Router#sh track
Track 123
Response Time Reporter 1 reachability
Reachability is Up
2 changes, last change 00:13:10
Delay up 10 secs, down 15 secs
Latest operation return code: OK
Latest RTT (millisecs) 8
Tracked by:
STATIC-IP-ROUTING 0
Track 345
Response Time Reporter 2 reachability
Reachability is Up
4 changes, last change 00:01:25
Latest RTT (millisecs) 11
See Routing table:
Router#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 72.252.205.1 to network 0.0.0.0
C 72.27.5.110/32 is directly connected, Dialer1
S* 0.0.0.0/0 [1/0] via 72.252.205.1, Vlan1
I am going to figure out how to end up with one route for vlan1 now (cosmetics really),by the way you notice how we still have vlan1 at [254/0],in the routing table. Anyway I think your contribution was ENORMOUS.
THANKS MUCH, AGAIN. RICK
(By the way, how do you rate posts?)
Gerald
Correct Answer
Richard Burts Mon, 03/10/2008 - 10:05
Gerald
Rick
Richard Burts Mon, 03/10/2008 - 13:14
Gerald
Especially if you do change that admin distance then it looks to me like it ought to work the way that you want it to. I am glad that my responses were helpful to you. Thank you for using the rating system to indicate that your issue was resolved (and thanks for the rating). It makes the forum more useful when people can read about an issue and can know that they will read responses that did resolve the issue.
The forum is an excellent place to learn about Cisco networking. I encourage you to continue your participation in the forum.
Rick
