Jaime Valencia Mon, 03/10/2008 - 05:55
  • Cisco Employee,
  • Hall of Fame,
    2011
if you're changing the subscriber DN that needs to be done in SAWeb, not in AD
you can try restarting the AVDsad service in Unity to force the refresh
javalenc
if this helps, please rate
richb1971 Mon, 03/10/2008 - 11:53
Hi Jaime,
Sounds promising although I'm confused why you'd need to do it somewhere other than AD? What is SAWeb? and would it update AD? Thought the idea was that AD was the definitive source?
Can you clarify please?
Rich
Jaime Valencia Mon, 03/10/2008 - 21:28
  • Cisco Employee,
  • Hall of Fame,
    2011
exactly what are you trying to do?
change the DN the user has as his mailbox or the telephone field in AD?
richb1971 Tue, 03/11/2008 - 02:05
CCM is sync'd with AD. I was hoping when we change the Telephone Number in AD it would change the DN in CCM. Is this possible?
Ta
Rich
Jaime Valencia Tue, 03/11/2008 - 07:56
  • Cisco Employee,
  • Hall of Fame,
    2011
The AD provides the directory, so if you change the telephone numer in AD that will reflect in the global directory as the phone number if you look for that guy, but that is not going to change the actual DN of the phone
that is not in the AD, that is in the CCM DB which is not synched at all with AD for that values
you need to go to device -> phone -> select the phone -> select the line and change the DN in there
javalenc
