ACS authorization query
sachin_mon
I would like to know what are the configurations required in Cisco ACS for authorization.
I have done the foll configurations in the switch.
aaa authorization config-commands
aaa authorization exec default group tacacs+ local
radius-server host 10.240.252.247
radius-server key greenland.123
Thanks.
Rgds.,
Sack
royalblues
Level 10
Level 10
Sachin,
Are you trying to authenticate and authorise your devices via Tacacs or Radius?
The AAA configuration defines the authorization group as tacacs whereas the server is configured for radius
aaa authorization exec default group radius local
On the ACS server it is very simple.
Go to Network configuration
choose a NDG and add the client
Fill in the details and choose authenticate using tacacs or radius
Narayan
Hi Narayan,
Sorry, I pasted the wrong configurations in the forum.Actual configurations in the device are as follows:
radius-server key xxx
I would like to know what are the configurations required in the ACS server with respect to authorization as we are using radius.Do we need to add anything else apart from adding the client in ACS..?
Thanks.
Rgds.,
Sachin
