VPN connections: impossible to ping network's machines
Mar 9th, 2008
I have configured a Cisco 857 device. I can connect to the internet. I can also establish VPN connections remotely.
However, once I have established a VPN connection, I cannot ping any system on the company LAN.
I have seen several posts on these forums but I couldn't configure properly my router.
I attach my config. Is it possible to know what corrections I should do?
My LAN IPs are 10.0.0.x with a subnet mask 255.0.0.0.
For my remote clients, I have now configured it to use 255.0.1.x.
Thanks and regards,
MaC
Overall Rating: 3 (1 ratings)
cisco24x7 Sun, 03/09/2008 - 10:31
  • Silver, 250 points or more
I can see in your configuration that you use
split-tunneling, which is fine.
However, I think you need add the following
line in the configuration so that your router
will NOT NAT traffics when going from 10.0.0.0/8 to 255.0.1.x/24:
no access-list 120
access-list 120 remark SDM_ACL Category=18
access-list 120 deny ip 10.0.0.0 0.255.255.255 192.168.1.0 0.0.0.255
access-list 120 deny ip 10.0.0.0 0.255.255.255 255.0.1.0 0.0.0.255
access-list 120 permit ip 10.0.0.0 0.0.0.255 any
That way, the traffics from 10.0.0.0/8 will not be NATted when going to
255.0.1.0/24 for the VPN.
CCIE Security
MaCFoxtrot Sun, 03/09/2008 - 10:59
To what does 255.0.1.x/24 refer? Is this a special range?
Wouldn't you rather mean 10.0.1.x/8 as 10.0.1.x will be the IP of the clients?
MaCFoxtrot Sun, 03/09/2008 - 11:23
Correction to my first post: "For my remote clients, I have now configured it to use 10.0.1.x."
MaCFoxtrot Sun, 03/09/2008 - 11:37
Here is the current state of my access lists; still nothing working:
access-list 100 remark SDM_ACL Category=4
access-list 100 permit ip 10.0.1.0 0.0.0.255 any
access-list 120 deny ip 10.0.0.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 120 deny ip 10.0.0.0 0.0.0.255 10.0.1.0 0.0.0.255
MaCFoxtrot Sat, 03/22/2008 - 03:50
The problem is now solved.
It was related to the fact that as well my company network and my VPN client pool were using IPs in the same subnet.
