SIP Outbound CallerID Problem
Answered Question
Mar 9th, 2008
Greetings, would you be able to help with an issue im having with CallerID, Inbound calls to my voice gateway successfully display the correct CallerID information but when I try to make outbound calls the endpoint displays the CallerID information as “888888888888”
I have tried different methods of manipulating the Calling number on my CME Router to translates the outgoing number to my main CLI “0121345****” as well as trying my SIP account number “844*****” but neither have any affect.
Any help you would be much appreciated.
Mark Rigby
Correct Answer by Paolo Bevilacqua about 9 years 2 weeks ago
If you verified the number to be right, complain to TSP and show trace as necessary. They may be the ones having the problem.
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Sun, 03/09/2008 - 12:00
  • Hall of Fame,
    Founding Member
Hi, the main test instrument is "debug ccsip message" with "term mon".
Then to understand why isn't working, you would need to mentioned first what do you want and how's configured now.
exonetinf1nity Sun, 03/09/2008 - 18:18
Indeed ive performed a debug when placing an outgoing call but cant find a reference to the "88888888888" translations.
CLI is 0121345**** (Partly edited)
The translation config is below
voice translation-rule 1
rule 1 /.*/ /0121345****/
voice translation-rule 2
rule 1 /^999$/ /999/
rule 2 /^9\(.*\)$/ /\1/
voice translation-rule 3
rule 1 /.........****/ /2001/
rule 2 /.........****/ /1005/
rule 3 /.........****/ /1006/
rule 4 /.........****/ /1007/
rule 5 /.........****/ /1008/
voice translation-profile SIP_Inbound
translate called 3
voice translation-profile SIP_Outbound
translate calling 1
translate called 2
and the dial peer in question is
dial-peer voice 1001 voip
description **Outbound call to SIP**
translation-profile outgoing SIP_Outbound
destination-pattern 9T
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
no vad
The call setup portion does show the calling number as being 0121345**** an intended.
The only other solution i can think of that there is another translation occurring with the registrar. Ive tested this on several different numbers.
Correct Answer
Paolo Bevilacqua Mon, 03/10/2008 - 02:39
  • Hall of Fame,
    Founding Member
exonetinf1nity Mon, 03/10/2008 - 09:14
Well after wrestling with the provider it was a fault at there end, i had expected this behaviour to enabled by default but you know what people say about assumptions!
Cheers for the reply anyhow.
Paolo Bevilacqua Mon, 03/10/2008 - 09:18
  • Hall of Fame,
    Founding Member
Exactly. First answer from SPs should be discarded by default.
Hope it helped, thanks for the nice rating and good luck!
