VPN 3000 network list
Answered Question
Mar 9th, 2008
I keep getting err msge "bad ip address/subnet mask/wildcard mask/area id" when trying to add a class C network to the list on a VPN 3000 concentrator using the CLI. Here's my entry 192.168.51.0/0.0.0.255. Both the number and wildcard mask seem ok. Isn't that the correct syntax?
Correct Answer by JORGE RODRIGUEZ about 9 years 2 weeks ago
Vincent, you are very welcome and thanks for the update..glad all worked out.. please rate post as resolved.
Bst Rgds
Jorge
Overall Rating: 5 (1 ratings)
JORGE RODRIGUEZ Sun, 03/09/2008 - 18:56
  • Green, 3000 points or more
Vincent,
Syntax is correct on whichever wildcard mask you want to use,however,when you are prompted to add a network wildcard information enter 192.168.51.0 firs then enter to proceed to wildcard mask info, you will be prompted to enter wildcard mask then place your 0.0.0.255 wildcard mask,you cannot place 192.168.51.0/ 0.0.0.255 on first network field.
Rgds
Jorge
vpersaud001 Sun, 03/09/2008 - 20:18
Jorge.... thanks. I tried that first and got an error on the first entry then tried with the slash and wildcard mask. I'll try it again and let you know.
JORGE RODRIGUEZ Sun, 03/09/2008 - 23:17
Yes, try it and let us know..btw..I've tried your network list entries without issues.
vpn3005: Network Lists -> 3
Current Network Lists
| 1. VPN Client Local LAN (Default) | 2. xxx_Remote_LAN |
| 3. test_L2L | 4. COMPANY-A |
1) Add a Network List
2) Modify a Network List
3) Delete a Network List
4) Copy a Network List
5) Back
vpn3005: Network Lists -> 2
> Which Network List to modify
vpn3005: Network Lists -> 4
1) Modify Network List Name
2) Modify Network List Contents
3) Back
Current Addresses In Network List
No Addresses In Network List
1) Add a Network/Wildcard
2) Modify a Network/Wildcard
3) Delete a Network/Wildcard
4) Back
bos-inet-vpn3005: Network Lists -> 1
> Network Address
vpn3005: Network Lists -> 192.168.51.0
> Network Wildcard mask
vpn3005: Network Lists -> [ 0.0.0.255 ] 0.0.0.255
| 192.168.51.0/0.0.0.255 | |
vpersaud001 Mon, 03/10/2008 - 06:14
Worked! and user has verified connectivity! Thanks very much for your help.
Correct Answer
JORGE RODRIGUEZ Mon, 03/10/2008 - 13:24
Bst Rgds
Jorge
