Vpn and Vlan's routing issue
Mar 9th, 2008
Hello Gentlemen,
I have a bit of a problem! I have a pix 500 series that connects physically to a 3560G switch. Switch has two Vlans (Vlan1 and Vlan 10). Pix internal ip address is, 3560G switch ip address is (Vlan1) and (Vlan10).
My problem is that PIX can ping any device that is on network, but when I VPN in I can't ping network.
I think I have configured the PIX with the right static routes?! I am confused why PIX can ping network and VPN client can't?
Please help!
I appreciate any suggestions!
brettmilborrow Mon, 03/10/2008 - 01:52
You need to make sure your VPN config on the PIX covers the networks from both VLANS.
Also check your internal routing to make sure that there are routes in place to cover your PVN client pool.
