Catalyst 4507 Restarting of its own
Hi we have 2 Catalyst 4507 for our core backbone. One is configured as primary and the other as secondary. Recently the primary core switch has started to restart on its own. This is happening 2-3 times daily and affecting us a lot.
Is this a known issue with the switch or we do have to apply some patches and updates?
Switch ver :
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I9S-M), Version 12
.2(25)EWA, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Fri 04-Mar-05 16:49 by dchih
Image text-base: 0x10000000, data-base: 0x114D6074
ROM: 12.2(25r)EW
Pod Revision 14, Force Revision 31, Tie Revision 29
SWITCH uptime is 17 hours, 24 minutes
Uptime for this control processor is 17 hours, 24 minutes
System image file is "bootflash:cat4000-i9s-mz.122-25.EWA.bin"
cisco WS-C4507R (MPC8540) processor (revision 10) with 524288K bytes of memory.
Processor board ID FOX092900H7
MPC8540 CPU at 800Mhz, Supervisor V-10GE
Last reset from PowerUp
23 Virtual Ethernet interfaces
64 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Please assist us.
Vik
royalblues Mon, 03/10/2008 - 01:47
  • Green, 3000 points or more
Do you see any error messages / tracebacks when the switch restarts?
Narayan
