MeetMe Conference with CME and CUE AutoAttendent
Mar 9th, 2008
Can someone do a sanity check to see if this is possible with a CME / CUE config. Management would like to define 6 MeetMe Conf numbers, each one assigned to a specific Exec. They would like both internal and PSTN callers to be able to join the conferences. Internal is no problem, but external seems a little tricky. My plan is to use CUE AutoAttendent and have one of the caller input options is to join a conference. The Autoattendent will then accept the digits from the caller and verify if it is a valid Meetme Conf extension, and if so, do a callredirect to that conference. Has anyone implemented something like this? Is this feasible. Do you have any CUE scripts that you can share on how to do the digit string collection and verification? Thanks all for your help!
Tom
