ASA 5510 - SSO for OWA using WebVPN
Mar 10th, 2008
Is it possible to configure a SSO for OWA (Form Based) on the ASA 5510?
Please Advise,
agjfritz84 Fri, 03/14/2008 - 13:33
I'm using 8.0(3). What I did was set up the SSO config for OWA under the group policy.
Configuration > Clientless SSL VPN > Group Policy. Select the group policy you're using (Probably default) and select Edit > More Options > Single Sign-On. What I did was set up a net block that I was using to push the creds to. If you want to use the URI, there's a guide in the 8.0 Config. Hope this helps!
