MPLs PE at customer device recommendation
Mar 10th, 2008
Wht kind of device would you recommend if you were to have mpls to your customer site and offer them both L2 and L3 services like internet service or remote site connectivity.
Are the catalyst 3750 Metro a good option for that or should we go for a router and do a trunk with our customer or install a switch behind to partition trafic on VRF/VLAN.
royalblues Mon, 03/10/2008 - 02:16
I would not recommend using a PE at the Customer premises.
THe choice of the device would depend upon the number of customer you would want to connect
Typically i would go for any ISR at the Customer site as CE and use a Metro switch to aggregate the CE connections (if on ethernet) and have a trunk to the PE which could be a 7206
csco10387876 Mon, 03/10/2008 - 02:33
I don't know if the ISR will be powerfull for our application, we have voice and data trafic for the customers and the often have at least 5-10 L3 VPN for remote site and RAVPN
royalblues Mon, 03/10/2008 - 03:08
I suggested the ISR for the CE edge router and not the PE. This anyway requires that you are managing the CPE as well
As for the PE, you should go with 7206 (or probably a 7609) depending on the number of links that are being terminated
