server vlan tagging
Mar 10th, 2008
Hi all, when configuring the network cards on my servers, should I tag the vlan on the server, or leave it untagged ? if I do tag the vlan on the server, what do I do at the switch end? do I just put the port into the same vlan, or create a trunk port ?
felix_liao Mon, 03/10/2008 - 03:33
you don't need to tag the vlan on the server, just configur the switchport which connect to your server to a vlan which you want it belongs to
