Position in the queue, average call duration
Mar 10th, 2008
Hi All;
How can I know the position of the call in the queue while the call is currently in the queue (at the ipivr)? And that is possible in the script or I have to go to the DB?
Also, from where I can know the average call duration for the calls were processed in the call center?
Overall Rating: 5 (1 ratings)
rbua Mon, 03/10/2008 - 04:29
Hi Bilal,
solutions I know of are a custom counter in the ICM scripts and a web service on a remote systems, both as you gather yourself are requiring extensive customisation.
bilalghayad Mon, 03/10/2008 - 06:04
Hello Riccardo;
Hope u r doing fine.
In the DB, no chance to find any field in some table to give the queue position for the a specific call that currently in the queue?
cherilynn1030 Mon, 03/10/2008 - 06:04
if you're using enterprise (we are using 7.1.5) this is what we do: Set a variable in the ICM script (again, in ours: skillgroup_xxx.routercallsqnow+1) and then in IVR we use a script, using Get Enterprise call info (the variable we set), we create a generated prompt number (with position) and the create a container prompt which concatenates our "you are caller number...XX"
we play that prompt, and then we return back to the ICM call flow.
If you're using IPCCX... then I"m not quite sure where you get the place in queue, but I imagine playing it back would be similiar to above....
bilalghayad Tue, 03/11/2008 - 02:37
Dear Riccardo;
Actually I need to know position of the call in the queue without need to prompt, I need this number (position in the queue) to use it for other purposes, it is enough for me just to know that now this call in position 1 or 2 or 3 of the queue as a data without hearing a prompt.
The question about ur suggested solution are:
1) It is not possible to find the position of the call in the queue from the DB?
2) If u r sending to the queue, then u increase the skillgroup_xxx.routercallsqnow by 1, so does that mean if the call existed the queue (because if call disconnected or if agent is available) then u decrease the skillgroup_xxx.routercallsqnow by 1?
3) If u need to decrease the skillgroup_xxx.routercallsqnow by 1 if the call disconnected while it was in the queue, then how u can notice that call disconnected and the queue free by one call, where in the scripts u can know that now call disconnected to reduce the variable skillgroup_xxx.routercallsqnow by 1?
4) If one agent become available and the call moved from the queue, then u decrease the skillgroup_xxx.routercallsqnow by 1 also?
Any advise?
Mormegill Mon, 06/02/2008 - 04:03
Hi all,
This seems rather straightforward in UCCX through CRA's IPCC Express editor steps. Can it really be all but impossible to get this funtionality operational in UCCE?
I'ts not really an exceptional function.
Anyone have any input on this?
bilalghayad Mon, 06/02/2008 - 04:14
What I have is IPCC Enterprise with CRS 3.1(3).
Any advise if it possible to be straight forward?
