Interface failover on single ASA
Mar 10th, 2008
We have 1 ASA firewall and 2 LAN switches. Can it be configured that the ASA connects in to both switches and in the event of switch failure connection to the firewall is still possible?
We have 4 interfaces on the ASA.
thanks
royalblues Mon, 03/10/2008 - 03:45
You cannot do this as the ASA will not allow to have the same IP subnet on 2 of its interfaces
If you need redundancy, then you require one more ASA box which can be configured for failover
Narayan
chris.rosan Mon, 03/10/2008 - 20:17
Mike,
That requires V8 code, which is still very early. I don't know that i'd be using it on a production system just yet.
