significance of Wism
Mar 10th, 2008
I am in the process of purchasing a 6500 and I need to understand if I need to purchase a wism and if it is relevant to my wireless network. I have 3 controllers at 3 diff sites. Each manage approx 20 access points. I plan on rolling out more controllers to my other sites and somewhere down the line expand the number of access points per site.
My question is, if I place a wism in my core switch, I will not need to purchase addiitonal controllers as I deploy wireless solution to futrue sites? From my understanding I thought best practice was to place a contoller at each site in on your wan.
Rob Huffman Mon, 03/10/2008 - 05:18
Hi Musumani,
Your thought is correct :) The WISM is really just a Blade that contains 2 WLC's. This will not change your deployment model at the remote sites. It would however be great to use if you are significantly increasing the number of AP's at the main site :)
Hope this helps!
Rob
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
