Crypto map question
If I have 2 crypto maps defined on my pix. Traffic of my first crypto map goes for tunnel 1 & traffic of my second interface goes for tunnel2.
I can't apply the command crypto map CCS interface outside & crypto map PLC interface outside.
I am able to apply only one.
How can I do to use both crypto maps?
crypto ipsec transform-set my_PLC esp-3des esp-md5-hmac
crypto ipsec security-association lifetime seconds 86400
crypto map PLC 30 ipsec-isakmp
crypto map PLC 30 match address PLC
crypto map PLC 30 set peer 10.10.10.1
crypto map PLC 30 set transform-set my_PLC
isakmp key ******* address 10.10.10.1 netmask 255.255.255.255
isakmp identity address
isakmp policy 30 authentication pre-share
isakmp policy 30 encryption 3des
isakmp policy 30 hash md5
isakmp policy 30 group 2
isakmp policy 30 lifetime 86400
crypto ipsec transform-set my_ccs esp-3des esp-md5-hmac
crypto map CCS 20 ipsec-isakmp
crypto map CCS 20 match address CCS
crypto map CCS 20 set peer 20.20.20.1
crypto map CCS 20 set transform-set my_ccs
isakmp key ****** address 20.20.20.1 netmask 255.255.255.255
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
wasiimcisco
Only one crypto map can be applied on one interface only in one direction. But one map can contain multiple profile with different sequence number.
You have to make
crypto map PLC 31 ipsec-isakmp
crypto map PLC 31 match address PLC
crypto map PLC 31 set peer 10.10.10.1
crypto map PLC 31 set transform-set my_PLC
and then apply the map on outside interface.
This is will work. Bcz i have tried it so many times.
If this will work please rate the post.
