Version conflict in Callmanager 5.1(3) while adding a node
Answered Question
Mar 10th, 2008
We are trying to add a subsequent node to a Callmanager 5.1(3) Cluster.
The first node is upgraded to 5.1(3)-2000, and when we try to install a node from DVD media with version 5.1(3)-1000 it states that the node cannot be added because the Publisher is a different version.
What's the correct procedure to add the node?
Correct Answer by Jaime Valencia about 9 years 1 month ago
during the install you get the option to apply a SR or ES, you need to download the upgrade file to 5.1(3)-2000 and apply it during the install of the SUB
javalenc
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Mon, 03/10/2008 - 05:47
  • Cisco Employee,
  • Hall of Fame,
    2011
javalenc
