Which process recovers CCM Webpage Admin Username?
Mar 10th, 2008
On CCM5.1.2 which process resets the CCM Admin Webpage back to CCMAdministrator? I've followed the guides to no avail. I can change the password but don't know the Username (the utils reset ui administrator password doesn't change the ID).
Rob Huffman Mon, 03/10/2008 - 06:34
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Richard,
I think this is the method you are looking for;
Recovering the Administrator Password
If you lose the Administrator password and cannot access the system, use the following procedure to reset the Administrator password.
Note During this procedure, you will be required to remove and then insert a valid CD or DVD in the disk drive to prove that you have physical access to the system.
Procedure
Step 1 Log in to the system with the following username and password:
Username: pwrecovery
Password: pwreset
The Welcome to admin password reset window displays.
Step 2 Press any key to continue.
Step 3 If you have a CD or DVD in the disk drive, remove it now.
Step 4 Press any key to continue.
The system tests to ensure that you have removed the CD or DVD from the disk drive.
Step 5 Insert a valid CD or DVD into the disk drive.
The system tests to ensure that you have inserted the disk.
Step 6 After the system verifies that you have inserted the disk, you get prompted to enter a new Administrator password.
When you get to this step you will get an option to Change either the administrator password or the security password.
Note The system resets the Administrator username to admin. If you want to set up a different Administrator username and password, use the CLI command set password. For more information, see Appendix A, "Command Line Interface."
Step 7 Reenter the new password.
The system checks the new password for strength. If the password does not contain enough different characters, you get prompted to enter a new password.
Step 8 After the system verifies the strength of the new password, the password gets reset, and you get prompted to press any key to exit the password reset utility.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/5_0/iptp_adm/504/iptpch2.htm#wp1040303
Hope this helps!
Rob
richb1971 Mon, 03/10/2008 - 07:32
Hi Rob.
Please don't let this one disappear into the Forum nether regions. Can anyone advise how to recover/change the CCMAdministrator WEB PAGE login?
I'm onsite and need it urgently.
Any help is much appreciated
richb1971 Mon, 03/10/2008 - 06:58
Hi Rob,
Thanks for reply but isn't that procedure to reset the CLI Username/Password. Don't think it applies to CCM Admin Page
Rich
Rob Huffman Mon, 03/10/2008 - 07:55
  • Hall of Fame,
    Founding Member
Hi Rich,
Ijust realised I sent you something different last month (my bad). Can you try;
From the CLI, use these commands:
utils reset_ui_administrator_password
**utils reset_ui_administrator_name
Hope this helps!
Rob
richb1971 Mon, 03/10/2008 - 08:01
Rob,
No probs....however....
**utils reset_ui_administrator_name Doesn't work on CCM5.1
:( HELP!
richb1971 Mon, 03/10/2008 - 08:35
Anyone any ideas how to reset the CCMWeb page Admin Username?
Jaime Valencia Mon, 03/10/2008 - 09:21
  • Cisco Employee,
  • Hall of Fame,
    2011
AFAIK there is no way to do so, maybe you can try this:
run sql update applicationuser set
password='f3f84fcd7934cd48ef4fef0d9057c21d000ffe229fbd0a247ee491927aa30f02' where
name='CCMAdministrator'
this sets CCMAdministrator to 'ciscocisco'
javalenc
if this helps, please rate
