03-10-2008 06:26 AM
If I have 2 crypto maps defined on my pix 506E. Traffic of my first crypto map goes for tunnel 1 & traffic of my second interface goes for tunnel2.
I can't apply the command crypto map CCS interface outside & crypto map PLC interface outside.
I am able to apply only one.
How can I do to use both crypto maps?
crypto ipsec transform-set my_PLC esp-3des esp-md5-hmac
crypto ipsec security-association lifetime seconds 86400
crypto map PLC 30 ipsec-isakmp
crypto map PLC 30 match address PLC
crypto map PLC 30 set peer 10.10.10.1
crypto map PLC 30 set transform-set my_PLC
isakmp key ******* address 10.10.10.1 netmask 255.255.255.255
isakmp identity address
isakmp policy 30 authentication pre-share
isakmp policy 30 encryption 3des
isakmp policy 30 hash md5
isakmp policy 30 group 2
isakmp policy 30 lifetime 86400
crypto ipsec transform-set my_ccs esp-3des esp-md5-hmac
crypto map CCS 20 ipsec-isakmp
crypto map CCS 20 match address CCS
crypto map CCS 20 set peer 20.20.20.1
crypto map CCS 20 set transform-set my_ccs
isakmp key ****** address 20.20.20.1 netmask 255.255.255.255
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
03-10-2008 09:21 AM
Crypto maps are like access list, one per direction,one per interface. Create a single crypto map to combine both previous crypto maps. An alternative is to maybe use GRE over ipsec and let a routing protocol select the best path for traffic and it will still be encrypted via the ipsec vpn.
03-10-2008 11:36 AM
You can only have one crypto map per interface but you can have separate entries within the same crypto map eg.
crypto map CCS 30 ipsec-isakmp
crypto map CCS 30 match address PLC
crypto map CCS 30 set peer 10.10.10.1
crypto map CCS 30 set transform-set my_PLC
Jon
