03-10-2008 07:12 AM - edited 03-05-2019 09:39 PM
I have a 3620 acting as my edge router. For reasons unknown it recently has been dropping its connection and not allowing any Internet activity. When this has occured, I tried to console in to it and that was even unavailable. (Just happened while I was typing this) I notice on the front of the unit are two activity lights for slot 0 and 1. During normal operation, only 0 is active. When this issue occurs, 1 is on steady and 0 is off.
We used to have a frame connecting our sites, but now have a different configuration so the only role this router has is connection to our Internet (DIA).
Two questions: 1) where can I look (logs)to see if there are any configuration or hardware issues; and 2) if I wish (and I do) to replace the unit, what would an equivilant unit be? Addendum to #2, I am planning on replacing my NS firewall with an ASA-5510.
Here is my current sh ru:
Building configuration...
Current configuration:
version 11.3
service timestamps debug uptime
service timestamps log uptime
hostname powi
enable password ******
ip subnet-zero
interface Ethernet0/0
ip address 68.78.90.226 255.255.255.224
interface Serial0/0
description Internet T1 via SBC
ip address 68.23.65.6 255.255.255.252
encapsulation frame-relay IETF
frame-relay map ip 68.23.65.5 659 broadcast
frame-relay lmi-type ansi
interface Ethernet1/0
ip address 64.211.222.130 255.255.255.192
interface Serial1/0
ip address 64.208.169.38 255.255.255.252
shutdown
interface Serial1/1
description Link to Grafton
ip address 172.20.201.1 255.255.255.0
encapsulation ppp
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 68.23.65.5
ip route 172.16.201.0 255.255.255.0 172.20.201.2
access-list 1 permit 172.16.0.0 0.0.255.255
access-list 111 permit ip 172.16.0.0 0.0.255.255 any
banner motd ^C
CONSTRUCTION FORMS PORT WASHINGTON ROUTER
NON-AUTHORIZED PERSONNEL DISCONNECT ^C
line con 0
line aux 0
line vty 0
password ****
login
line vty 1 3
login
line vty 4
password ****
login
end
My show ver:
IOS (tm) 3600 Software (C3620-IS-M), Version 11.3(6)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1998 by cisco Systems, Inc.
Compiled Wed 07-Oct-98 09:38 by ccai
Image text-base: 0x600088E0, data-base: 0x60842000
ROM: System Bootstrap, Version 11.1(19)AA, EARLY DEPLOYMENT RELEASE SOFTWARE (fc
1)
powi uptime is 9 minutes
System restarted by power-on
System image file is "flash:c3620-is-mz_113-6_T.bin", booted via flash
cisco 3620 (R4700) processor (revision 0x81) with 18432K/6144K bytes of memory.
Processor board ID 09197395
R4700 processor, Implementation 33, Revision 1.0
Bridging software.
X.25 software, Version 3.0.0.
2 Ethernet/IEEE 802.3 interface(s)
3 Serial network interface(s)
DRAM configuration is 32 bits wide with parity disabled.
29K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
03-10-2008 07:50 AM
You can look at the logs , with the "show logg" command . You also may be the only person left still running 11.X code , you should really think about upgrading the code within the constraints of the memory installed on the box .
