Switch CLI Credentials
Mar 10th, 2008
We have four MDS switches here and one of them keeps asking for "Switch CLI Credentials" when I run "Show Tech Support" from Device Manager. The other three work fine. When I put the correct username & password it still comes back with the same error.
ebreniz Fri, 03/14/2008 - 09:29
  • Silver, 250 points or more
Switch getting managed even after deleting valid CLI credentials. Try this bug CSCsh31390
andyhp1 Wed, 03/26/2008 - 10:27
are you sure the CLI account you are using works on that switch ? have you tried openg a command line session to check the user and password are correct ? DM and FM use a different account to the CLI.
user_4444 Thu, 03/27/2008 - 04:29
All four switches use the same username and password and I get into DM & FM using these credential's. I Also get into CLI by the same way. I can open DM on this switch using the same credential's but get the error when trying to run "Show Tech-Support".
Trending Topics: Storage Networking
