InterCluster CME calls using 7985?
Mar 10th, 2008
Hi there,
I need to verify. Can we connect two CME systems to make video calls using 7985 SCCP phones? or can we make video calls using 7985 between a CCM and CME as well?
Brandon Buffin Mon, 03/10/2008 - 08:46
  • Purple, 4500 points or more
Yes, this should work as long as you have IP connectivity and the bandwidth to support video calls.
Hope this helps. If so, please rate the post.
Brandon
Jeremy Lim Mon, 03/10/2008 - 08:51
Thanks, but how about CME to CCM 7985 Video Calls. Can they work as well?
Brandon Buffin Mon, 03/10/2008 - 08:53
Yes, assuming IP connectivity and sufficient bandwidth.
Brandon
