DST udpate not working on Unity 4.2
Tommer Catlin
Any reason why DST patch would not work? I have (2) windows 2000 Unity servers that do not keep their time correctly. They are getting time from a BDC in the network, but that should not affect the daylight savings locally on the machine would it?
Any tips would be great!
Ginger Dillon
Hi -
Here is the KB article for Unity and DST - you might check to make sure the patch is applied on your Unity server - http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K90543054
Regards, Ginger
Thanks Ginger. I found that article also this morning. I have a feeling the Windows patches were not applied so then the cisco DST patch has no effect on the machine for DST.
