Joe Clarke Mon, 03/10/2008 - 09:34
It looks like there was an error fetching the startup config for this device. To troubleshoot this, enable ArchiveMgmt Service debugging under RME > Admin > System Preferences > Application Loglevel Settings, then run a Sync Archive job for this device after checking the Fetch Startup Config box. The dcmaservice.log should have any relevant errors.
Joe Clarke Mon, 03/10/2008 - 19:49
The archive has become out of sync with the database. You need to remove this device from RME, then re-add it, and that will cause the archive to resync.
