Need help with WLC 4400 Setup
Answered Question
Mar 10th, 2008
I have a client that is currently running 2 seperate WLANs. One is configured with 10 LWAPs connected back to a WLC 4400 using MAC Authentication. The other is 2 stand-alone 1200 Series APs configured with RADIUS to a MS IAS server.
The client would like to combine the seperate WLANs into 1; Effectively bringing all APs into the WLC, configuring RADIUS for all, and keeping the 2 current seperate SSIDs.
Is this possible using the 4400 Series? If so, Could you please direct me towards the guides for this setup.
1. Convert 1200 Series APs to LWAPs
2. Configure RADIUS on WLC 4400
3. Configure 2 seperate SSIDS on 1 WLC both using the same auth method
4. Modify RADIUS policys on MS Windows 2003 IAS if need be
Correct Answer by sabhasin about 8 years 11 months ago
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a00808e5d6b.shtml
> This should be fairly simple...
There are several IAS configuration examples here:
http://www.cisco.com/en/US/products/ps6366/prod_configuration_examples_list.html
Overall Rating: 5 (1 ratings)
Correct Answer
sabhasin Mon, 03/10/2008 - 09:57
sabhasin Mon, 03/10/2008 - 10:12
no worries. glad it helped. don't forget to rate any helpful posts :)
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
