CM4.2(3) - voice interruptions
Mar 10th, 2008
Hi!
When in the middle of a call there are some voice interruptions from time to time. The call does not go down but there are some silence moments and some words can't be heard when that happens.
This is a connection to a PSTN.
What could be the problem?
Best regards,
Ana
Jaime Valencia Mon, 03/10/2008 - 10:36
that could be caused by packet drops, the RTP flow is not stable and some packets are dropped or lost along the way which causes that effect.
do you have any QoS config on the network?
javalenc
if this helps, please rate
abartolomeu Mon, 03/10/2008 - 10:40
Hi!
No I didn't configure any QOS since it is a connection to a PSTN. Maybe I need it anyway.
Ana
