ethernet channel
Answered Question
Mar 10th, 2008
What is the pros and cros between
EtherChannel
and
stack
if I want to link up two or more L3 switches (e.g. CAT3750)
rdgs
Correct Answer by paolo bevilacqua about 9 years 4 months ago
Hi, if one switch fails, the surviving ones should keep configuration.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Mon, 03/10/2008 - 12:11
  • Hall of Fame,
    Founding Member
When available, you should always use stack, like in the 3750 that gives you a 32 Gbps connection and makes the switch appears like a single one.
anitachoi3 Tue, 03/11/2008 - 06:57
I stack the two switches, e.g. switch A and switch B. They stack to each other and treat it as single big switch.
If the switch A (or switch B) is down, can I access the switch?
If yes, how about the config?
e.g.
I config switch A with Vlan 2, 3, 5 and 7 for first 24 ports.
I config switch B with Vlan 3, 7, 10, 15 for the next 24 ports.
Do they keep itself config?.
rdgs
Correct Answer
paolo bevilacqua Tue, 03/11/2008 - 07:25
  • Hall of Fame,
    Founding Member
