Unity and AD schema update
Mar 10th, 2008
Hi all,
I'm having problems running the ADSchema update with Unity 4.0 and Exchange 2003
When running it, an error occurs:
"Setup failed to query the "AllowedChildClassesEffective" attribute" I've made sure that this is the Schema Master, I dont have any Anti-Virus running...
Any ideas?
Overall Rating: 4 (2 ratings)
Jaime Valencia Mon, 03/10/2008 - 12:49
are all the domain controllers online?
try running the ADSCHEMASETUP directly on the exchange box
In general you need to verify these things first:
- add the account logged into the server as part of the enterprise
admins and schema
admins groups
- change the schema master to the correct domain controller (check with the schema management plugin in mmc which DC currently has the role)
- change the registry key to allow schema updates:
if this helps, please rate
pferraz Thu, 03/13/2008 - 09:56
The problem was the registry key, that wasn't updated
Txs for the help|
Tray Stoutmeyer Mon, 03/10/2008 - 19:37
Another thing in addition to the other post here...
Make sure you are running the ADSchemaSetup.exe directly on the Schema Master server and not from a mapped drive. I see you say this is the Schema Master you are running this on but make sure you either copy the whole DVD/CD over to a directory on the server or just copy the SchemaUpdate folder from the DVD/CD over to it and run it directly there. That, or have the DVD/CD that has the ADSchemaSetup in the Schema Master drive and run it from there.
