Call Forward All for inbound calls to external numbers
Answered Question
Mar 10th, 2008
Hi there,
We have the problem that we want to forward incoming external calls to a cell phone at sometime. However this does not work at the moment. When chosen call forward all to an external number and one rings the internal extension. This works fine. When somebody dials the DID number one hears ringing but no call is forwarded to the external destination.
Included you will find the script. Furthermore the debug of the successfull call transfer all when dialing the internal number and the debug of the non successfull call transfer all when the DID number is called.
Correct Answer by paolo bevilacqua about 9 years 3 months ago
Hi, should be:
voice translation-profile doorschakel
translate called 4
the reason the "isdn map address" under bri0/1/0 is not working is because it should be like:
isdn map address . plan unknown type unknown
this command has the same effect like the translation-rule, so after it's fixed, you don't need both.
In fact "isdn map address" is simpler.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Mon, 03/10/2008 - 12:40
  • Hall of Fame,
    Founding Member
Which exact IOS are you using? There's a candidate bug related to to the "invalid IE" you receive when placing the call.
In any case, please upgrade to XW6 and try again.
mamkreutz01 Mon, 03/10/2008 - 12:46
Hi there,
I am using the 12.4<11>XW5 release. Do you thin upgrading to the XW6 could solve this problem ?
mamkreutz01 Mon, 03/10/2008 - 13:13
Hi there,
Ok i did the upgrade to the XW6 release but the problem stays the same. I hear ring but no calls are forwarded to the external number.
paolo bevilacqua Mon, 03/10/2008 - 13:53
  • Hall of Fame,
    Founding Member
Hi, can you edit or produce a trace that starts with the incoming call form outside that has to be forwarded?
Previous traces have multiple calls and is not clear what is what.
mamkreutz01 Mon, 03/10/2008 - 13:57
Hi there,
Thanks for the quick reply. Look below for a single trace:
Mar 10 20:56:05.251: %LINK-3-UPDOWN: Interface BRI0/1/0, changed state to up
Mar 10 20:56:05.327: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x27
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Progress Ind i = 0x8283 - Origination address is non-ISDN
Calling Party Number i = 0x2183, '455650910'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '433270325'
Mar 10 20:56:05.339: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0xA7
Channel ID i = 0x89
Exclusive, B1
Mar 10 20:56:05.343: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x2
0x1, Calling num 0433270323
Mar 10 20:56:05.355: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x2
0x1, Called num 0645388001
Mar 10 20:56:05.359: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8 callref = 0x0B
Standard = CCITT
Channel ID i = 0x82
Preferred, B2
Calling Party Number i = 0x2183, '0433270323'
Called Party Number i = 0xA1, '0645388001'
Sending Complete
Mar 10 20:56:05.547: ISDN BR0/1/0 Q931: RX <- STATUS pd = 8 callref = 0x8B
Cause i = 0x82E41E - Invalid information element contents
Call State i = 0x01
Mar 10 20:56:05.607: ISDN BR0/1/0 Q931: RX <- STATUS pd = 8 callref = 0x8B
Cause i = 0x82E46C - Invalid information element contents
Call State i = 0x01
Mar 10 20:56:05.647: ISDN BR0/1/0 Q931: RX <- CALL_PROC pd = 8 callref = 0x8B
Channel ID i = 0x8A
Exclusive, B2
Mar 10 20:56:07.975: ISDN BR0/1/0 Q931: RX <- PROGRESS pd = 8 callref = 0x8B
Progress Ind i = 0x8282 - Destination address is non-ISDN
Mar 10 20:56:07.979: ISDN BR0/1/0 Q931: TX -> ALERTING pd = 8 callref = 0xA7
Mar 10 20:56:08.071: ISDN BR0/1/0 Q931: RX <- STATUS pd = 8 callref = 0x27
Call State i = 0x07
Mar 10 20:56:12.035: ISDN BR0/1/0 Q931: RX <- DISCONNECT pd = 8 callref = 0x8B
Cause i = 0x8290 - Normal call clearing
Progress Ind i = 0x8288 - In-band info or appropriate now available
Mar 10 20:56:42.067: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x8B
Mar 10 20:56:42.071: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0
B
Mar 10 20:56:42.091: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8 callref = 0xA7
Cause i = 0x8090 - Normal call clearing
Mar 10 20:56:42.147: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x27
Mar 10 20:56:42.147: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xA
7
Mar 10 20:56:52.191: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Mar 10 20:57:03.407: ISDN BR0/1/0 Q931: L3_ShutDown: Shutting down ISDN Layer 3
Mar 10 20:57:03.459: %LINK-3-UPDOWN: Interface BRI0/1/0, changed state to down
paolo bevilacqua Mon, 03/10/2008 - 15:07
  • Hall of Fame,
    Founding Member
Hi, this is a bit strange, it appear that the calling side (455650910) is disconnecting first, the forwarded call is placed regularly, altought with two complans from the switch:
1st, setup message from router has progress indication IE (0x1e). That is about the bug I was mentioning before, CSCsi94745, it should be resolved in XW6 anyway
Then, calling number (IE 0x6c) is not in right format, how telco expect the calling number to be, probably without 0?
All in all is very strange. First of all I would like to see the call to be palced without IE complaints from the switch. To do this:
1. try 12.4(11)XJ4, and 2. fix the calling number.
Also, the trace "internalNumber" above I never see a connect message. How you can tell you were talking without connect message ?
mamkreutz01 Mon, 03/10/2008 - 23:09
How do i fix the calling number ? Is there a command in CME for it to do this ? Trace Internal Number the Cell Phone rings we did not pick up the call. In the situation of the CFA when calls are coming in from outside the cell phone never rings.
mamkreutz01 Mon, 03/10/2008 - 23:40
Hi there,
I removed the clid network-number command from the dial-peers. Result stays the same. Below a new trace of that:
Mar 11 06:38:33.029: %LINK-3-UPDOWN: Interface BRI0/1/0, changed state to up
Mar 11 06:38:33.101: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x2D
Sending Complete
Standard = CCITT
Channel ID i = 0x8A
Exclusive, B2
Mar 11 06:38:33.109: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0xAD
Channel ID i = 0x8A
Exclusive, B2
Mar 11 06:38:33.117: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x2
0x1, Calling num 260
Mar 11 06:38:33.129: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x2
0x1, Called num 0611395292
Mar 11 06:38:33.129: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8 callref = 0x10
Standard = CCITT
Channel ID i = 0x81
Preferred, B1
Calling Party Number i = 0x2183, '260'
Called Party Number i = 0xA1, '0611395292'
Sending Complete
Mar 11 06:38:33.281: ISDN BR0/1/0 Q931: RX <- STATUS pd = 8 callref = 0x90
Call State i = 0x01
Mar 11 06:38:33.341: ISDN BR0/1/0 Q931: RX <- STATUS pd = 8 callref = 0x90
Call State i = 0x01
Mar 11 06:38:33.377: ISDN BR0/1/0 Q931: RX <- CALL_PROC pd = 8 callref = 0x90
Channel ID i = 0x89
Exclusive, B1
Mar 11 06:38:37.749: ISDN BR0/1/0 Q931: RX <- PROGRESS pd = 8 callref = 0x90
Mar 11 06:38:37.753: ISDN BR0/1/0 Q931: TX -> ALERTING pd = 8 callref = 0xAD
Mar 11 06:38:37.821: ISDN BR0/1/0 Q931: RX <- STATUS pd = 8 callref = 0x2D
Call State i = 0x07
Mar 11 06:39:12.493: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x2D
Cause i = 0x8A90 - Normal call clearing
Mar 11 06:39:12.497: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xA
D
Mar 11 06:39:12.517: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8 callref = 0x10
Mar 11 06:39:12.761: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x9
paolo bevilacqua Tue, 03/11/2008 - 03:27
  • Hall of Fame,
    Founding Member
Both 260 and the number that begins with 0 are causing invalid IE. perhaps telco wants the number without 0 or a different type/plan.
I will look for a way to not send the PI IE in setup, there should but I don't remember now.
mamkreutz01 Tue, 03/11/2008 - 03:40
Hi there,
Thanks for your quick reply. Yes if there is a way to get this working i would be very thankfull. It is a standard function should work, most customers of ours also want it.
paolo bevilacqua Tue, 03/11/2008 - 04:23
  • Hall of Fame,
    Founding Member
The thing is that is your telco switch that behave strangely, this works in all installations I've seen.
Anyway, try under bri:
no isdn outgoing ie pi
no isdn outgoing ie caller-number
The objective is to place a call without receiving status messages from switch.
mamkreutz01 Tue, 03/11/2008 - 04:46
Hi there,
Problem stays the same. Look for output below:
Mar 11 11:45:19.596: %LINK-3-UPDOWN: Interface BRI0/1/0, changed state to up
Mar 11 11:45:19.716: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x4F
Sending Complete
Standard = CCITT
Channel ID i = 0x89
Exclusive, B1
Calling Party Number i = 0x2183, '650831293'
Mar 11 11:45:19.728: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0xCF
Channel ID i = 0x89
Exclusive, B1
Mar 11 11:45:19.732: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x2
Mar 11 11:45:19.744: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x2
Mar 11 11:45:19.748: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8 callref = 0x2C
Standard = CCITT
Channel ID i = 0x82
Preferred, B2
Sending Complete
Mar 11 11:45:19.948: ISDN BR0/1/0 Q931: RX <- CALL_PROC pd = 8 callref = 0xAC
Channel ID i = 0x8A
Exclusive, B2
Mar 11 11:45:23.920: ISDN BR0/1/0 Q931: RX <- PROGRESS pd = 8 callref = 0xAC
Mar 11 11:45:23.924: ISDN BR0/1/0 Q931: TX -> ALERTING pd = 8 callref = 0xCF
Mar 11 11:45:55.820: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x4F
Mar 11 11:45:55.824: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xC
F
Mar 11 11:45:55.844: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8 callref = 0x2C
Mar 11 11:45:56.048: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xA
C
Mar 11 11:46:06.188: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
mamkreutz01 Tue, 03/11/2008 - 04:48
The difference we have seen is that when a call forward functions to an external number that there is the entry:
Plan: Unknown Type: Unknown
When it is not functioning like above there is an entry in the trace:
Plan : ISDN Type: National
Maybe this helps ?
paolo bevilacqua Tue, 03/11/2008 - 05:04
  • Hall of Fame,
    Founding Member
Yes, try forcing type/plans unknown/unknown with a translation-profile for called number at either DP or voice-port level.
rule 1 // // type any unknown plan any unknown
Telco is definitely misbheaving by clearing the call without indicating an exact reason for that.
mamkreutz01 Tue, 03/11/2008 - 06:52
Hi there,
When we put in this rule at the voice port or at the DP then the to be forwarded call is directly disconnected. So no normal call clearing then.
paolo bevilacqua Tue, 03/11/2008 - 07:24
  • Hall of Fame,
    Founding Member
Send the trace again. Also send the trace when forward is successful from an internal phone.
Make sure there is a connect and you can talki for the latter, because the first trace you sent, did not showed connect.
paolo bevilacqua Tue, 03/11/2008 - 09:07
  • Hall of Fame,
    Founding Member
Hi, the forward from external is still palced isdn/national:
Mar 11 15:50:20.355: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8 callref = 0x4F
Standard = CCITT
Channel ID i = 0x82
Preferred, B2
Called Party Number i = 0xA1, '00611395292'
Sending Complete
How did you configured the voice translation-rule ? You need to tie it to a voice translation-profile that in turne is applied as outgoing at voice-port or DP level.
mamkreutz01 Tue, 03/11/2008 - 09:24
Hi there,
Look below for the configuration of the DP:
voice translation-rule 4
translate calling 4
voice-port 0/1/0
compand-type a-law
cptone NL
I tried to put here at the voice port the rule translation-profile outgoing doorschakel but then the external caller recieves no ring tone at all.
Furthermore i put it in the DP below:
dial-peer voice 10 pots
description Uitgaand lokaal
destination-pattern 0[1-9]T
port 0/1/0
forward-digits all
When i put the outgoing translation-profile here then i do not get a ring tone when calling from external.
Maybe a problem with the BRI configuration ?
Look below:
interface BRI0/1/0
description Nummer 043-3270323
no ip address
isdn switch-type basic-net3
isdn overlap-receiving
isdn point-to-point-setup
isdn incoming-voice voice
isdn map address type plan unknown type unknown
isdn sending-complete
no isdn outgoing ie progress-indicator
isdn static-tei 0
Thanks in advance for your reply.
Correct Answer
paolo bevilacqua Tue, 03/11/2008 - 09:36
  • Hall of Fame,
    Founding Member
Hi, should be:
translate called 4
mamkreutz01 Tue, 03/11/2008 - 10:17
Hi there,
Thank you very very much. After applying the rule you mentioned everything is working fine now.
Your help is greatly appreciated.
paolo bevilacqua Tue, 03/11/2008 - 10:34
  • Hall of Fame,
    Founding Member
Oh, that one took some time. Thanks for the nice rating and good luck!
