CCME in SOHO :- Diverting Fax calls to fxs port
Mar 10th, 2008
I have a situation where a custom is will have CCME and has a fax machine attached to an FXS port.
All PSTN calls come through a single FXO trunk.
There is no DID for FAX calls.
If I want to divert incoming fax calls to go to a dial-peer on which the fax machine is attached, do I need to setup the TCL script for Fax detection ?
paolo bevilacqua Mon, 03/10/2008 - 11:28
  • Hall of Fame,
    Founding Member
Hi, I've tried a tcl script with the commands for fax detections, and could not have it working.
So I think you need to direct the call via an extension anyway.
