Translation Patterns and CSS/Partition
Mar 10th, 2008
I'm having an issue creating a translation pattern and assigning it to an extension if that extension is part of a partition. When I dial the entire phone number from my extension, I get a phone not in service error. Here's the example:
Local extension - 3333
Device CSS- TeachersCSS
Line 1 Parition - TeachersPT
Line 1 Directory Number Settings CSS - TeachersCSS
Partitions:
TeachersPT
InboundPattersPT
CSS:
InboundPatternsCSS(InboundPattersPT, TeachersPT)
TeachersCSS(TeachersPT, InboundPattersPT)
Translation Pattern:
Partition - InboundPatternsPT
CSS - InboundPatternsCSS
The idea of the pattern is to provide a DID for that extension. If no partitions are assigned to the phone and the pattern, the DID works properly.
Any ideas what I'm missing? TIA
iec1088407 Mon, 03/10/2008 - 11:32
your Gateways is a H323 or MGCP, if it is H323 you will need to change the CSS for Inbound calls
iancarder Mon, 03/10/2008 - 11:43
Thanks for the response. The gateway is MGCP. I changed the CSS for the T1PRI port 0/0 on the inbound calls section to InboundPatternsCSS. That didn't help.
Jaime Valencia Mon, 03/10/2008 - 21:32
  • Cisco Employee,
  • Hall of Fame,
    2011
OK, so what you want is to map 4 digits that are coming from the PSTN to an IP phone that does not have that 4 digits as internal extesion?
if so what you need to do is configure the inbound CSS for the GW to reach the TP , under the TP configure the called number as the IP phone you want to reach and make sure the CSS of the TP is able to reach the destination IP phone
javalenc
iancarder Tue, 03/11/2008 - 07:37
Thanks for the help. Unfortunately, I already have those pieces configured and I'm still running into a brick wall. I've just opened a TAC request, so we'll see where that goes. If I get it sorted out, I'll report back.
