Removing License from CCM 6.1
Mar 10th, 2008
  • Silver, 250 points or more
Does anyone know how to remove a license from Cisco Unified Communications Manager 6.1?
I was told that no one can get root access, and I am under the assumption that you need root to be able to do this. Is there a way to do this without rebuilding the server?
Jaime Valencia Mon, 03/10/2008 - 12:28
  • Cisco Employee,
  • Hall of Fame,
    2011
Open a TAC case and reference this bug:
CSCsg28075
Administrator does not have ability to remove licenses from CallManager
they should get the root access with this bug ID and remove the license file
javalenc
if this helps, please rate
