UC500 moh issue
Mar 10th, 2008
Hi, I have a problem with music on hold on my UC500. I use the default file music-on-hold.au but I listen only noise. The same file on CME work correctly.
There's a way to debug this problem?
Thanks Enrico
paolo bevilacqua Mon, 03/10/2008 - 11:55
  • Hall of Fame,
    Founding Member
Which exact IOS are you using? Also try reloading the router.
epasqualotto Mon, 03/10/2008 - 13:02
The IOS version is 12.4(11)XW6 but also with 12.4(11)XW5 I have the same problem.
Seems that UC500 cannot reproduce the music, like play the first 1-2 second forever.
I have checked the CPU/Memory/Bandwidth utilization but all are ok.
Enrico.
paolo bevilacqua Mon, 03/10/2008 - 13:06
  • Hall of Fame,
    Founding Member
Is it possible that the file got corrupted? Have you tried another one ?
epasqualotto Mon, 03/10/2008 - 13:35
Yes yes, I try also with the CUE sound file but the "noise-on-hold" are the same.
paolo bevilacqua Mon, 03/10/2008 - 13:41
  • Hall of Fame,
    Founding Member
I've never heard of CME having a problem with MOH. Send relevant config, as it is strange.
epasqualotto Mon, 03/10/2008 - 13:56
telephony-service
video
no auto-reg-ephone
max-ephones 14
max-dn 56
ip source-address 10.1.1.1 port 2000
auto assign 10 to 19
auto assign 5 to 8 type anl
calling-number initiator
service phone videoCapability 1
timeouts interdigit 2
system message Netspin
url information http://192.168.99.254/ciscoxml/information.php
url directories http://192.168.99.254/ciscoxml/localdirectory.php
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
time-zone 23
time-format 24
date-format dd-mm-yy
voicemail 2100
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh en_bacd_music_on_hold.au
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern .T
transfer-pattern 0.T
secondary-dialtone 0
create cnf-files version-stamp 7960 Mar 10 2008 21:03:07
This is my conf, I don't have see similar problem too.
If you want to listen I can send you our pstn number.
Enrico.
Fair_Serg Wed, 03/19/2008 - 04:33
ip source-address and multicast moh must have different ip and ports
multicast moh 239.10.16.16 port 5000
mattcalderon Wed, 03/19/2008 - 05:23
  • Silver, 250 points or more
AFter looking at the config I dont see the multicast commands.
Summary of MOH.
1. enable
2. configure terminal
3. telephony-service
4. moh filename
5. multicast moh ip-address port port-number [route ip-address-list]
6. exit
7. ephone phone-tag
8. multicast-moh
9. end
From this guide:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmemoh.html#wp1010384
Note: This command is required to use MOH for internal calls and it must be configured after MOH is enabled with the moh command.
epasqualotto Thu, 03/27/2008 - 07:20
My MOH issue also is on ISDN call via BRI. I think this is a moh generation problem from au/wav
