Nat on cisco-2500
Mar 10th, 2008
Hi seniors, following is the output of sh version
Copyright (c) 1986-1997 by cisco Systems, Inc.
Compiled Mon 22-Sep-97 21:23 by ckralik
Image text-base: 0x030228E8, data-base: 0x00001000
ROM: System Bootstrap, Version 11.0(10c)XB1, PLATFORM SPECIFIC RELEASE SOFTWARE
(fc1)
BOOTFLASH: 3000 Bootstrap Software (IGS-BOOT-R), Version 11.0(10c)XB1, PLATFORM
SPECIFIC RELEASE SOFTWARE (fc1)
R3 uptime is 2 hours, 11 minutes
System restarted by power-on
System image file is "flash:c2500-i-l.112-9", booted via flash
cisco 2500 (68030) processor (revision L) with 14336K/2048K bytes of memory.
Processor board ID 01514827, with hardware revision 00000000
Bridging software.
X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
Basic Rate ISDN software, Version 1.0.
1 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
1 ISDN Basic Rate interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read ONLY)
--More--
I am trying to configure nating, but when i use command ip nat inside on serial0, it gives me error message, Is that IOS is old ? Please guide. Thanks. Tahir.
paolo bevilacqua Mon, 03/10/2008 - 12:51
  • Hall of Fame,
    Founding Member
Not only is 11 years old, but in 11.2 plus image (with an s in the filename) are required for NAT.
At least you've 16 MB of ram to load a newer, larger image.
