CME 7941G and cached configurations?
cschear
I had been having issues with making "url idle" changes to my configuration, resetting phones, and them not obtaining this configuration. I must have made the config change a couple dozen times. At some point, they 3 phones I have in my lab received the config change but when I removed it from my Unity installation, they KEPT loading the "url idle" long after it was no longer in my running or start-up configuration.
I rebooted the CME router. While the router was down I physically powered cycled the phones. Once everything was back up, the phones STILL had the "url idle" values configured! While in the SETTINGS of a particular phone, I typed *,*,#,*,* to unlock and choose "Erase" on the HTTP Configuration option. This removed all the entries, but now I can't get them to populate again with the fields I actually desire: Directory, Services, Authentication, etc.
I'm at a loss why my GUI and CLI changes to my "url" paramters are "sticking" on the phones, and not being downloaded to the phones upon a reset.
Thoughts?
paolo bevilacqua
May be an IOS and phone FW issue. State which IOS you have, which phones and which FW currently.
No FW. Output of "show version" below.
rt-cme#show ver
Cisco IOS Software, 2801 Software (C2801-SPSERVICESK9-M), Version 12.4(15)T3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 24-Jan-08 16:38 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
rt-cme uptime is 37 minutes
System returned to ROM by reload at 13:33:00 CST Mon Mar 10 2008
System restarted at 13:34:46 CST Mon Mar 10 2008
System image file is "flash:c2801-spservicesk9-mz.124-15.T3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2801 (revision 7.0) with 236544K/25600K bytes of memory.
Processor board ID FTX1205Z00L
2 FastEthernet interfaces
1 terminal line
2 Voice FXO interfaces
1 DSP, 8 Voice resources
1 cisco service engine(s)
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
Forgot the phones...
All 3 are 7941G phones:
App Load ID Jar41sccp.8-2-2ES1.sbn
Boot Load ID 7941G_64-02070631Amd64megRel.bin
Version SCCP41.8-2-2SR1S
Hardware Revision 1.0
8.2(2)SR4S is available for the phones. Beside that, more conservative would be running 12.4(11)XJ4 that still has more bug fixes that 12.4(15)T3.
