ASA 5510 Remove VPN configuration
I am having some problems with the configuration af Remote VPN.
I have just received a new ASA 5510 and I have made the basic configurations so that I can browse the internet. I then went through the VPN Wizard and I can connect to the VPN without any problems but I can't connect to the internet through the VPN tunnel. I want all the traffic to pass through the VPN tunnel so no split tunnel.
Our configuration is:
Outside interface: Static public IP
Inside interface: 192.168.1.0
I am using the latest ASDM and ASA software.
As far as I am informed it should be possible to connect to the Outside interface through VPN and go back out to the internet through the same interface, but how do I configure it?
I have searched and searched and I can't find a solution to the problem.
Is there any special settings I need to be aware of?
/Lasse
vkapoor5 Mon, 03/17/2008 - 08:38
  • Bronze, 100 points or more
This document describes how to set up a PIX Firewall 7.0.1 and later to perform IPsec on a stick. This setup applies to a specific case where the PIX does not allow split tunneling, and users connect directly to the PIX before they are permitted to go to the Internet.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00805734ae.shtml
