Problem with WS-C3750G-24PS
Mar 10th, 2008
Hello, I have problem con switch WS-C3750G-24PS in Stack. this is a Sh ver
System image file is "flash:c3750-ipbasek9-mz.122-25.SEE4/c3750-ipbasek9-mz.122
25.SEE4.bin"
cisco WS-C3750G-24PS (PowerPC405) processor (revision F0) with 118784K/12280K b
tes of memory.
Processor board ID FOC1124Z6DC
Last reset from power-on
2 Virtual Ethernet interfaces
112 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:1B:0D:CF:78:80
Motherboard assembly number : 73-10217-07
Power supply part number : 341-0108-03
Motherboard serial number : FOC112428DY
Power supply serial number : DCA1122A1WU
Model revision number : F0
Motherboard revision number : B0
Model number : WS-C3750G-24PS-S
System serial number : FOC1124Z6DC
Top Assembly Part Number : 800-26855-01
Top Assembly Revision Number : C0
Version ID : V05
CLEI Code Number : CNMWR00ARC
Hardware Board Revision Number : 0x09
Switch Ports Model SW Version SW Image
* 1 28 WS-C3750G-24PS 12.2(25)SEE4 C3750-IPBASEK9-M
2 28 WS-C3750G-24PS 12.2(25)SEE4 C3750-IPBASEK9-M
3 28 WS-C3750G-24PS 12.2(25)SEE4 C3750-IPBASEK9-M
4 28 WS-C3750G-24PS 12.2(25)SEE4 C3750-IPBASEK9-M
Mar 10 22:00:52.187 UTC: PSECURE: Assert failure: psecure_sb->info.num_addrs <=
psecure_sb->max_addrs: ../switch/psecure/psecure_utils.c: 129: psecure_update_a
dress_counts (TCBB3750VDP5-4)
Mar 10 22:00:52.187 UTC: -Traceback= 6BB870 6C6CC4 6C883C 663C 7A18 4DE2AC 579E
8 57A038 909AAC 90000C (TCBB3750VDP5-4)
dress_counts (TCBB3750VDP5-3)
8 57A038 909AAC 90000C (TCBB3750VDP5-3)
dress_counts (TCBB3750VDP5-2)
8 57A038 909AAC 90000C (TCBB3750VDP5-2)
Mar 10 22:02:53.083 UTC: PSECURE: Assert failure: psecure_sb->info.num_addrs <=
Mar 10 22:02:53.083 UTC: -Traceback= 6BB870 6C6CC4 6C883C 663C 7A18 4DE2AC 579E
Anyone know what is this error?
gogasca Mon, 03/10/2008 - 21:38
  • Green, 3000 points or more
Hola Santiago
Im not familiar with sw you may post your question in network infraestructure section
They can help you better there.
