Mar 10th, 2008
I have a 2800 router with IOS Version 12.4(9), when I try log in my router with SDM i complicates Sign do it, but also this error appear with the Cisco Configuring Assistant.( I need to put my password 3 times)
when I login in the SDM or CCA, the application doesn't allow me to make any changes in my router
aborole Mon, 03/10/2008 - 17:14
what version of CCA do you have ?
what is the exact error in CCA ?
Which feature in CCA are you trying to use to make changes on 2800 router ?
Do you mean the GUI is grayed out and you cannot edit the parameters ?
dflores83 Mon, 03/10/2008 - 17:34
the cca version is 1.1(1)
In cca I can't login, when i assign the ip address i can't login on router.
I don't know if the router have some error with the autenthication on HTTP or some protocol.
aborole Mon, 03/10/2008 - 17:52
if you are not able to log into the device this could be http authentication issue. you could try from a browser and see what is needed in order to be able to issue htp commands like http:///exec/show/version/CR - the credentials that will allow you to successfully issue that command from a browser should also work with CCA
dflores83 Tue, 03/11/2008 - 09:22
thanks, I read the site and I saw this data.
but the error is in the SDM where the application doesn't allow me to make any changes in my router.
