CUPS Hardware
Mar 10th, 2008
Is CUPS like CUCM in the sense that it will not install on a non-approved server, or is it like Unity which can be installed on just about anything?
I have seen the CUPS hardware matrix so I know what is officially supported but I only need this for testing so a non-MCS would be preferable.
Overall Rating: 5 (1 ratings)
Rob Huffman Tue, 03/11/2008 - 06:08
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Robert,
Sadly the install will likely fail at the Harware check step
The installation next checks to see whether you have a supported hardware platform. If your server does not meet the exact hardware requirements, the installation process fails with a critical error.
http://www.cisco.com/en/US/docs/voice_ip_comm/cups/6_0_1/install_upgrade/installation/guide/cpins601.html#wp83749
Have you thought of going the VMWare route instead? This is supported for lab testing;
Support for VMWare usage of Cisco Unified Presence for lab, demo, and application development activities
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps6837/prod_bulletin0900aecd806f742d.html
Hope this helps!
Rob
