Performance problem on router
Mar 11th, 2008
Hi All,
PLease kindly assist me with the following problem:
I have a Cisco 7606 router with IPSEC VPN SPA installed. I have been experiencing performance challenges on this device. The device currently functions are my WAN aggregator, terminating over 1000 links. The following services run off this device:
Over 1000 GRE tunnels , each running IPSEC, to remote offices
RIP between the remote offices and the central office
OSPF between the device and two other devices within the core
Please find attached , show outputs from the device.
Overall Rating: 5 (1 ratings)
Danilo Dy Tue, 03/11/2008 - 05:03
  • Blue, 1500 points or more
PID 319 is causing excessive CPU usage.
Possible...
- IOS Bug
- Debug is turn ON, disable it by executing "no debug all" or "undebug all"
Check the logs if there is any possible problem.
If you have a back-to-back maintenance with Cisco, capture the output of "show tech-support" and "show stacks 319". 319 is the PID of the process causing the high CPU utilization. Log a case to TAC
Dandy
