2610 card installation
Mar 11th, 2008
Hi, is it possible for me to add one more WIC-1B-S/T to my 2610 router with following configuration
Slot 0:
C2610 1E Mainboard port adapter, 5 ports
Port adapter is analyzed
Port adapter insertion time unknown
Hardware revision 2.2 Board revision A0
Serial number 3291806978 Part number 73-2839-12
Test history 0x0 RMA number 00-00-00
EEPROM format version 1
EEPROM contents (hex):
0x20: 01 91 02 02 C4 34 FD 02 49 0B 17 0C 00 00 00 00
0x30: 50 00 00 06 00 00 00 00 00 00 00 00 00 00 00 00
WIC Slot 0:
Serial 2T (12in1) WAN daughter card
Hardware revision 1.0 Board revision B0
Serial number 33716081 Part number 800-03181-02
Connector type PCI
0x20: 01 12 01 00 02 02 77 71 50 0C 6D 02 00 00 00 00
0x30: 58 00 00 00 05 06 21 00 FF FF FF FF FF FF FF FF
WIC Slot 1:
Hardware revision 1.0 Board revision C0
Serial number 20033713 Part number 800-03181-01
Connector type PCI
0x20: 01 12 01 00 01 31 B0 B1 50 0C 6D 01 00 00 00 00
0x30: 60 00 00 00 00 08 07 00 FF FF FF FF FF FF FF FF
Slot 1:
4 PORT Voice port adapter, 4 ports
Hardware revision 1.1 Board revision D0
Serial number 13286554 Part number 800-02491-02
0x20: 01 65 01 01 00 CA BC 9A 50 09 BB 02 00 00 00 00
0x30: 68 00 00 00 99 03 17 17 FF FF FF FF FF FF FF FF
VIC Slot 1:
FXS Voice daughter card (2 port)
Hardware revision 1.1 Board revision F0
Serial number 13923939 Part number 800-02493-01
Connector type Wan Module
0x20: 01 0E 01 01 00 D4 76 63 50 09 BD 01 00 00 00 00
0x30: 78 00 00 00 99 04 28 01 FF FF FF FF FF FF FF FF
Is there any free port?
Please advice
