Integrating IPCExpress with CMExpress
Mar 11th, 2008
I have a problem with this integration. The validation between both is OK from IPCC web page validation.
IP IPCCE: 192.168.0.111
IP CME: 192.168.0.253
The problem is that when I create a JTAPI Trigger on IPCCExpres with a new application and a script, and dial the trigger (5000) to test it, always is busy. I don't get that works ok.
Any help please?
Thanks by advance
Fernando Lacarra Tue, 03/11/2008 - 04:20
I reply myself.
The only thing that I've changed is the number on "Outbound Trigger DN". (Subsystem->Unified CME Telephony Provider). Then restarted the CRS Engine.
