Hardware Question..
Mar 11th, 2008
Hello everyone..
where should I post a hardware question:
It regarding a Cisco 3550, I need convert the AC power to DC power..??
Is there a form I can post on? is this the rigth place..
Let me know..
Mavrick25 Tue, 03/11/2008 - 06:16
Thanks for the post.
I knew that the Redundant Power System for Cisco 3550 exisited and could be a solution.
I am looking more for an answer as to if...
With Cisco 3550 can you hot-swap the AC Power with the DC power supply...
Most likely not.. but I thought I would ask..
Let me know
Goutam Sanyal Tue, 03/11/2008 - 22:30
Yes, we are running a Cisco 2800 with the AC power supply where we are using CISCO RPS 675 and if any problem it comes up with out affecting the Cisco 2800
Hope I am informative.
Pls rate if it helps U!!!
