1841 router booting problem
Mar 11th, 2008
hi
i have 1841 router whos IOS ver is 12.4(1c).when i power on the router first it start booting then decompress the IOS then it suddenly stop booting at bellow mention point
"Port Statistics for unclassified packets is not turned on."
please tell me whats exatly problem and also tell me is this router support to IPV6?
Overall Rating: 3.7 (3 ratings)
Goutam Sanyal Tue, 03/11/2008 - 05:43
  • Silver, 250 points or more
Hi Parba,
Can you post the booting image? Also let me know that if upgrade the IOS? The routers decompress the image while booting because it is compressed into the IOS file. That's how it is with the new IOS's. Don't think it is may trouble you. For Details : http://www.cisco.com/en/US/docs/routers/access/1800/1841/software/configuration/guide/b_rommon.html
For the next one can visit http://tools.cisco.com/ITDIT/CFN/, which is a good way to find out any feature Cisco IOS & CatOS.
Goutam
Pls rate if it helps u!!!
vaisharm Tue, 03/11/2008 - 06:37
  • Cisco Employee,
Hi Praba,
Upgrade the IOS to the latest 12.4 mainline code and you won't see this problem. Alternately, you may try to skip the startup-config and that might help as well. You can then copy the config again, save it and reload.
To prevent the startup config from loading, break into rommon by pressing ctrl+break during the initial few seconds when the router is powered on. From rommon prompt issue 'confreg 0x2142' and then 'reset'. Now, the router would not load the configuration and would be in the setup dialog. Exit it by pressing ctrl+C. Copy the config back to the router, change the configuration register back to 0x2102 and then save & reload.
Here's how you can change the config-register back to the default 0x2102
router(config)#line con 0
config-register 0x2102
end
write mem
reload
Yes, this router does support IPv6. However, you would need one of the following feature sets:
ADVANCED ENTERPRISE SERVICES or
ADVANCED IP SERVICES
HTH, do rate if it does.
~Vaibhav
lamav Tue, 03/11/2008 - 06:48
  • Blue, 1500 points or more
Praba:
If you follow Vaibhav's procedure, make sure you execute a "copy START run", not "copy RUN start" when you "copy the config back to the router" or you will blow out your config.
Victor
vaisharm Wed, 03/12/2008 - 00:44
  • Cisco Employee,
Oops..I just overlooked that. Thanks for pointing that out Victor.
~Vaibhav
Goutam Sanyal Tue, 03/11/2008 - 21:47
Hi Vaibhav,
I'd like to clarify the use of “line con 0” as per my concern changing the “config-reg value”, "line con 0" is not required. Pls correct me if I am wrong.
Goutam
Goutam Sanyal Wed, 03/12/2008 - 01:40
I am agreeing with you. But how can I assume that you are asking to change the consol speed by your below output.
end
write mem
reload
Goutam
vaisharm Wed, 03/12/2008 - 02:15
  • Cisco Employee,
You are right, this should be:
router(config)#config-register 0x2102
router(config)#end
The 'line con 0' is not needed. I was looking at two different posts and mixed them up. To avoid any further confusion for Praba - changing the console speed is NOT related to this post. We first change the config regsiter to 0x2142 from ROMMON to prevent the router from loading the configuration (to rule out the possibility of this being a config related issue).
1. Issue the break sequence to drop into ROMMON mode.
2. ROMMON>confreg 0x2142
3. ROMMON>reset
4. You would see the initial configuration setup. Press Ctrl + C to exit out.
5. At this point you may manually configure the router if the old configuration was not needed. Else, do 'copy start run' to use the old config.
6. Change the configuration register back to the default:
router(config)#end
7. You may now save the config and reload the router.
However, if after reboot you run into the same issue again it would mean there's still some misconfiguration. You would have to follow the entire procedure till step 4 and then do manual configuration. Once this is done follow step 6 and 7.
HTH,
~Vaibhav
Goutam Sanyal Wed, 03/12/2008 - 02:20
Hi Vaibhav,
Extremely right, have doubt that post only. Now it's Okay :)
Goutam
