Ciscoworks Backup to a network drive LMS 3.0
Mar 11th, 2008
I have LMS 3.0 and would like to backup the database to another server/network drive. Is this possible and how do I do it?
In common services would i need to manually type the path: \\<server address>\<drive> ??? or similar???
Joe Clarke Tue, 03/11/2008 - 09:06
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is not possible. You _could_ mount the drive (i.e. assign it a letter), then try the backup, but this would be ill advised given that network issues could corrupt your backup. But, if you have a reliable, fast network, it should work.
r.gill Tue, 03/11/2008 - 09:09
Hmm ill try mounting the drive/share and seeing if that works. Our network is quite stable. However, i do agree with you about corrupt backups. The customer is keen to backup everything to a seperate server....hmm lets see! thank u for your help.
Martin Ermel Tue, 03/11/2008 - 09:16
  • Blue, 1500 points or more
another way to go is to store the backup local (as designed by LMS) and setup a script that copies the backup-files over the network. You can also verify that the copy process was successfull (md5 checksum) and schedule the job with at or crontab.
r.gill Tue, 03/11/2008 - 09:18
yes that wud be useful!!!....hmm i shall see if the customers backup facility does that.... thank u
